I believe the Charger requires Charger parts, at least in the roof, and probably the quarter as well. The roof and how it attaches to the quarter is pretty radically different then the other B body cars, I can't believe anything under the sheet metal would be correctly located, but I suppose that would depend on how deep into the structure you need to replace. Gene
