What efi system are you using? Curious because some systems really can cause chaos if duty cycle goes static. Are you sure you're not just over fueling the program at higher rpms? If you can look at pulsewidths in your fuel table, make sure at each load point that your pulsewidth doesn't increase once you get past peak TQ rpm.
Its a fast XFI program
It had 83 lb injectors and a 2 bar sensor
I will be adding 120 lb injectors and change to a 3 bar map sensor
And then we will need to remap everything
Do you have any suggestions on keeping datalog and program files?
I like to save all the table with a specific name
and then name the datalog file the same same for comparison
It makes for a log of files but I find it easier to compare
