He can bolt on a set of 11.75" dia rotors from the parts store for like ~$75ea or less. And then buy the 11.75" caliper adapters for alike $50-$75 a set. Same bearing and calipers he has now.
that's what I did & made a world of difference(I cheated though & added some better quality pads). If you do need to replace calipers the 76 A body ones have a 2.75" piston dia as opposed to 2.60" in 73-5 A bodys, gives you more bias toward the front where you need it most.
