Originally Posted By A12
Originally Posted By Morty426
Noise reduction
Winner......tap a brake drum with and without the spring with a wrench or similar steel object and you'll hear the difference. Or spin the drum with and without the spring and while it's spinning touch the wrench or screwdriver to the spinning drum..again you'll hear the difference.
MikeR
That makes total sense. It's a harmonic dampener.
