Originally Posted By Supercuda
Originally Posted By B5 Bee
Since higher octane fuel generally has less energy per gallon
Since that is an incorrect statement I'd say any conclusions derived from it would be incorrect as well.
Gasoline has the same amount of energy per gallon, regardless of octane.
All octane levels do is affect detonation and/or preignition.
Assuming nothing different other than octane levels you will see nothing changed.
Gasoline is a blend and gas blends can vary in energy BTU/gal as much as 4% in the summer/winter blends. Of course the octane doesn't reduce the BTU content, but without any additives such as TEL, the blend needed to get gas to a higher octane generally does.
