Specs on mine is 222/228 @ .050 107 LSA with +3 ground into the cam. lift is .544/.544 with Magnum 1.6 ratio rockers.
I'm sure if you called them and asked for a 'custom grind' they would run it for you.
**Photobucket sucks**
