I recently repaired the center carb on a 70 Cuda so I replaced the metal fuel lines with a repro set. I decided to use the original brass fuel blocks because the repro didn't look correct. After tightening and re-tightening all the fittings from the carbs to the fuel blocks, they are still leaking. Is there a lube or trick to prevent the fittings from leaking gas?
