So I have an SN93 Supercharger I am putting on a small block stroker and was wondering if anyone has messed with this charger on any small block or big block applications. Right now I am in need of brackets, and wanted to know if anyone knows of sources for the brackets? The goal is an E85, blow thru carb set up. Mainly a keep it simple motto...
I currently have the magnum bracket but it does not fit, and would rather not cut it, if I sell the kit someday.
Justin
I've had friends that used that exact blower and they seize-up a lot. Actually just about all the Paxton's had that problem.
