As Ahy and Mattox already said, extra spring will change the spring rate.
Think of it as increasing coil thickness on a coil spring. Not the solution if height is what you want to change.
Rearch is the best solution.
69 Super Bee, 93 Mustang LX, 04 Allure Super
