Originally Posted By madscientist
Originally Posted By 493_DART
Originally Posted By RapidRobert
I have a NIB set of 315-0029 perfect circle single moly 30 over 440 rings 1/16 1/16/ 3/16. $49 to your door. email me. box is ratty/rings were out of the box & are perfect.
thanks--but i just need 1 hole.
Doesn't sound like a bad deal. Not a lot of money and then you'll have spares.
X2. Summit's $13 ring set is going to cost you $23 unless you spend $100. You might as well just buy Rapidrobert's ring set. You'll really kick yourself in the butt if you buy just one and end up needing another set.
