I have taken street wedge 426 to +.070 over, which is standard 440 bore size work
I did have that block sonic tested first and it was good, it was a late 1964 street casting shruggy
Have a good shop sonic test his and go from there twocents
The other option already mentioned is to sleeve it, which I like to stay away from unless I have a excellent shop that know exactly how to do one cylinder without distorting the rest of the cylinders on that side shruggy
Good luck, let us know what you guys do thumbs
