According to the Standard catalog of Chrysler 1924-1990:
56 Plymouth (all models) had a 115" wheel base and an over all length of 204.8"
56 Dodge had 120" wheel base, and had an over all length of 213".
It was pretty typical of a Dodge to have a longer front end then a Plymouth had. You may have to alter the rear edge of the Dodge front fenders to match up with the Plymouth wheel base.
Its an old car, a torch and a welder can put nearly anything together.
I type slow! 57 was the introduction of the unibody construction. Both 56's should be body on frame. A Dakota front end has been put under at least one of these cars, I think its story is right here on Moparts. Its not a simple job. Gene
