I've never personally seen a 74 with the solid stripe, I think it might have been a late year thing. I've seen the ball shifter before, but the two of these cars I've owned with the slap stick both had the t handle shifter. My current 74 has a column shift, and it was an original 400 hp car. The 74 dash has the little icons next to the headlight and wiper switch, you can see them in the pics in the brochures. My current dash is out of a 73, and has a 150mph speedo. The other cars I've owned were all 120mph. So not sure what options you had to order to get those things.
