Hi All,
I am installing a set of aftermarket oil pressure, temp, and voltage gauges in a '71 Charger.
What is the proper way to tie the lights for the gauges into the electrical system?
Right now the wire for the light on my tach is just pinched in with a fuse in the fuse block, I know that is not the right way, and I want these gauges to be done correctly.
All advice is appreciated.
Greg
