if you are decoding the fender tag properly? is there a broadcast sheet?
you could also request an IBM decode from FCA Historical & see the original selling dealership & option info, to compare with family recollections
how late in the model year was the car built?
there should be some supporting evidence on/with the car that would verify whether or not the engine has been changed: parts, date codes, castings, etc.
