The combo 90 tube chassis Daytona: 2550 with driver, 4 link rear w/4.30 gear, Strange struts up front, 727 w/TA convertor that flashes 5600. Motor: Ported W2's by RyanJ, 11.2 CR, 416 CI, 2" headers, Edlebrock Victor W2, C&S aerosol billet alcohol 900 carb. MY ROCKERS ARE 1.6's
Cam 1: Racer Brown grd# SXT22 IO@52* before TDC IC@78*@ABDC
EO@82*BDC EC@48*ATDC This was from the provided cam card. Specs from a web site" http://www.4secondsflat.com/RB%20Cam%20Specs.htm
Cam 2: Ultradyne grd# NF63F6 IO@47* before TDC IC@*ABDC EO@79*BBDC EC@35*ATDC Card indicates a 100* CL on the intake and 112* on the exhaust. Says to degree intake lode to 100*
Question 2 With cam 1 I have .115 piston to valve clearance at TDC. The cam is in @ 108* Will I be able to run the UD and have enough clearance to put it in at 100*
