I might go FI in 3-4 years so I will redo the entire fuel system then, for now I'm sticking with simplicity and going with a good basic pump (electric or mech) that will fill my needs. I should add it is a half filled block so the oil will run hotter and have been told that could make the mechanical fuel pump hotter as well, giving me more reason to run a return line.
