I would buy the female hydraulic steel fitting (nut and sleeve) to put on the 1/2 line, if it is steel, aluminum fittings if it is aluminum, and a #6 to #8 male union and hook the two lines together up scope
I've done that with larger AN lines with no issues wrench
