If you run out of ideas you can put the pulley in a press and rebend it to the depth you need to line up. I have done this to quite a few over the years. Then install it on the pump, clamp the pump in a vise and spin it to check pulley run out. If you need to adjust it you can just bend it by hand. The 3 spoke pulleys are very easy to bend.
The only Carbs I care about are under the hood!
