Most off these use a mechanical lock nut and don't need to be very tight. I just use an open end wrench to tighten them and that is all you need. Once the nut stops against the shackle STOP TIGHTENING IT or you will snap it off.
Gus beer
64 Plymouth Savoy
493 Indy EZ's by Nick at Compu-Flow
5-Speed Richmond faceplate Liberty box
Dana 60
