Here is an interesting video showing 8 02 sensors. Megasquirt 3 can adjust cylinder trim per cylinder if you give it the data from 8 02s. Look how crazy the trim is until everything starts working together. I can't remember how much power they said this was worth but on an engine masters entry any power is worth it, I want to say it was 10-12HP under the curve.
