Here is the problem I have. My front end is a FatMan MustangII frt. My rear suspension is out of a 1990 T-Bird SuperCoupe. Even after I widened my rear fenders 2" I still need a wheel with 6"or 7" offset and only 1" toward the front. In order to get a wheel large enough to clear the upper a-arms and calipers it has to be 16" or larger. Every company that builds those wheels does not make a matching set for the front. The front has to be no larger than 15" and no wider than 5" with a 4" offset in order to clear the fenders and calipers, and upper a-arms. My wife insists that all 4 wheels are the same design. Budnik wheels want $1800.00 for 4 wheels made to my measurements so I guess that is where I am headed.
