Check for gas residue in the MAP sensor. At 1,800 rpm, it might not be a throttle issue. Maybe the MAP is faulty causing a high timing advance condition. Check your coolant sensor also, if it dips cold momentarily, it might raise the idle speed thinking it needs to warm up some more.
