I had the same problem restoring my 1968 Charger. I used a reproduction hose with all the wrong bends. I have thought since of sending my hose to Classic Auto Air in Tampa, Fla. They did my AC lines. They reused the original hose ends and replated them, then soldered on new crimp sleeves to hold the new rubber. I don't see why they couldn't do the same for a power steering hose. AC systems are under the same high pressure as a power steering system. Give them a call and see what they say.
