I know some of you wont like this but I purchased the KC661 kit. I Know I know. It mimic's the original.
Cam Lift Exhaust (Inch) 0.3090
Cam Lift Intake (Inch) 0.2990
Cam Series Pro-3000
Cam Type Hydraulic
Duration @ .006 Lift 292/309
Duration @ .050 Lift 214/225
Engine Family Big Block
Exhaust Duration 225
Exhaust Lift (Inch) 0.4640
Exhaust Lift (MM) 7.849
Exhaust Valve Lift 1 (MM) 11.786
Footnote Code (050) Duration at .050 Lobe Lift
Intake Duration 214
Intake Lift (Inch) 0.4490
Intake Lift (MM) 7.595
Intake Lobe Center 110
Intake Valve Lift 1 (MM) 11.405
Lobe Separation 115
Manufacturer Chrysler
Overlap 46
Thanks again for all of your input.
