mine starts and idles perfect even -20 if I let it idle a minute or two I don't even have to feather it, but who wants to drive when its that cold any how, rub out start car com back in 5 minutes and I am good to go. I have a t-quad with no choke. If the base timing is tuned to perfection and your mixture screws are set right when warm you can give them an extra 1/4 turn open and it will richen it up enough to run god cold. If your timing is compromised at all it will make it harder to get it to run good cold. Also need to make sure your air bleeds are set right, a good quality mix burns better when cold. Also you need to make sure it is not a holley because they ocasionally back fire when the tune is slightly off and blow power valves.
i wouldnt expect a guy named HOTRODDAVE would run a choke. chokes are not hot roddy
