Originally Posted By bonefish
Did you run it w/the stable in the tank?if not i would pull the carb and give it a freshen up.
ONLY if the truck will not start or run well..
WAY TOO MUCH overkill on posts like this....
if you follow this advice at least have a big towl and a fire ex. handy incase your floats are stuck.
I didn't know '99 rams came with carburators.
Was that a option....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
