A friend of mine is a supplier for both AMD and Goodmark.
I examined the inner fenders for a customer well enough to form an opinion that the AMD are the ones I would use..
I don't have pictures here, but stamped holes for items like wiring clips etc appeared to be off on a couple spots on the Goodmark.
However.... a bit off topic, let me show a few pictures of the AMD rad support which I myself would not use.
First picture shows welded studs for the horizontal top support on an AMD followed by the original stud head on an original support.
Third picture is of the nuts used several places on the side supports on AMD supports and forth pictures is original side support nuts
