Here is a view of one inner fender. Above the intercoolers there is a air pump (smog) from a modern can re-purposed as crank case vac's. One each side connected to each valve cover. I have the PCM control them through a pulse width module. From 500rpm to 2000rpm they run at 30%. From there they ramp up to 100% by 3500rpm.
