The engine setup is a simple 410 stroker, 4" Eagle crank, KB pistons, 3" magnaflow exhaust,hydraulic roller cam, 750 dp mechanical carb, Msd pro billet distributor & digital 6AL electronics, B&M 727 TF, clutch type power lock on a 489 8.75 w/3:55's. What width wheel and BSM are you running?
