Try getting stuck behind a couple of junior dragsters. I think they unload and then wait till the starting line to do EVERYTHING. They start it, warm it, set the carb, talk, do a couple hops, talk some more, set the carb again, and finally take forever to stage.
And when there are more than one, they will only run one at a time so that none of the kids get discouraged by losing a test pass.
Last time I was out, one pulled straight into the burn out box while we were in the staging lanes. Then 3 more were pushed up behind him/her. I bet it took 10 minutes for them to get down the track. I was trying to make a 2nd pass and had to pull out of the staging lanes cause I couldn't keep the temp where it needed to be waiting that long.
