you need to get the number off of the choke horn and cross reference it with this chart. It will tell you which metering block you need
http://www.holley.com/data/TechService/Technical/Carb%20Numerical%20Listing.pdf
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
