Not trying to be negative , but what's the big deal about holding in a button on your wheel when backing up. Your hand( hands are on the wheel anyhow) guess I don't understand the issue. nothin if you only back straight up. And with a dedicated race only car, that's about all you would need to back up for, is out of the trailer or off the starting line if somebody broke.......or put the button on a detachable cord so you have better control if you have to saw the wheel
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
