Originally Posted By Supercuda
Regarding the rear brakes, let whom ever is building your Dana know what brakes you wan to run so they can use the correct housing ends and axle offsets.
As for how they work, well got a 98 Exploder with those brakes and they seem to work fine.
Definately will let the rear end builder know, I need just a bare housing with axles to do the 4 link, then I will have it all powdercoated before it gets gears
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
