finally got decent weather to get the car out and do the maiden voyage on the new trick flow headed 512 and was very happy with the resuls, right out of the trailer it went 6.22@108.6 in the 1/8th mile, second pass was a little slower at 6.29@108.6 because of slippage on the line,(I failed to check the tire pressure and it was a little higher than it should of been by 2.5 pounds), so I footbraked both passes had 31* timing and shifted at 6200 to start out and the plugs are a little hotter than I usually run and the carb is a little fat so it's tunin' time.
