So a kid that helps me out around the shop wanted to port his own eagle heads he is going to put on an older 5.7
I notice the bowl has a big machine cut in it that I havent seen before.
I flow the head and its the best damn eagle head I have flowed. Being that he has very little experience porting this turned into a blessing.
I checked my other eagle heads around the shop and none are like his set. Flow numbers untouched are .1 78 .2 135 .3 207 .4 263 .5 300 .6 325
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
