I found out the hard way a long time ago to not use low tension oil rings on any motor that didn't have a vacume pump or dry sump oil system on the motor, especially STREET motors tsk
Stick with the 1/16,1/16 and 3/16 standard tension oil rings and set the end gaps on the wide side, not on the tight side tsk twocents
