Originally Posted By Cab_Burge
Go to KB, United Machine, web site and use their on line compression ratio calculator and plug in your specs. with both + .025 deck height and then .500 down specs. up scope
Do you know the valve reliefs CC? If so deduct that from both measurements to keep it even work confused
no calc on that website using .500 downfill .....thx anyhow
