well they are kind of dark but you can see both sides tuck up in the chassis with collectors about center of pan rail.
the deep pan or the fluid drip off the drain plug is the lowest point under the truck.
firecore wires/90* plug boots behind the header tubes with heat socks. don't really need the socks
