You can get the pan off if you move it out of the way and unbolt the pickup tube.I have a 98 4x4 auto I did this too.Slow oil pressure buildup could be a plugged pick up tube.Mine was.It now takes 3 seconds to move the needle.Check your timing chain.Mine is very loose at 86,000.I suspect it is rattling at startup and light throttle.
