You could get by with that much IF you're using a forged piston like an older TRW 11.5. Even then you will need to let the engine warm up before hammering on it. If using a cast piston, you better look to getting it bored. I usually bore using a cast piston when it gets over .005".
I love the smell of Deer guts in the morning, it smells like... VICTORY!
