Originally Posted By AndyF
The cylinder head guys use tubes all the time to seal up the oil passages or other things so tubing should be available. I wouldn't think you would need a press fit to hold it in place since it can't really go anywhere. Maybe a little dab of locktite on the outside of the tube when you slide it into place.
^^^^^^^^^^This. You don't need press fit on something like that.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
