i'm going to check out a tube chassis car next week, i've always had back halfed street cars so what does one look for with a tube chassis?
The car has box section in the middle with tubed extentions front & rear. A steel shell has been fitted & a glass front clip. A Mark Williams fabricated 9 3/4 differential with Strange case & floater axles. It's 4 bar rear, Front struts & a Strange Steering rack fitted. Some tin work still needs doing but has a floor tunnel over the trans & a driveshaft loop inside the car. This is an unfinished project from 2x previous owners. Both owners had gone the Hemi Route so BBM is an easy fit. Since its never been a finished racecar, what things would i need to pay attention to when i'm looking at everything? Anybody got pics of theirs or someones project? it's not quite a Pro Mod but its getting close.
That thing is miles away from being a ProMod!
If I were you I would pass on this thing.
How fast are you wanting to go?
I doubt that chassis would pass any cert.
