getting started on a 1969 340 .040 418.
This block was ORINGED BY LAST OWNER and can i run it only with cometics ?Hard blocked also .
We are upping the compression to 13.5+ with head studs .4"callies dragonslayer stud main caps probe custom pistons .050 + out of deck, chevy rods , lite pins,MM rings change some top end oiling .Cam change stx22 cam from stx21 .same ported eddies as on 410 C.I Looking at 9.90s
thanks don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
