My 2 cents on that above Dakota chassis; Look close, you will have to redo the crossmember the 4 link is mounted to if you want to add a driveshaft, the guy ran a full steel tube across the truck and tied the 4 ling to it. If he made that kind of error, what else is in question? The price seems a little steep for what your buying. Gene
