Just curious....has anybody tried the Harbour Freight spot welder they have for something like $29.95? I really don't think I'd want to trust it for the actual weld, but would it "reproduce" the spot weld look if you hit the plug welds with this.
I can't imagine a $29.95 spot welder being "hot enough to melt anything? but at that price it's disposible... you could try it! I use a lenco spot here... they're under $1000 and have all sorts of attachments available. For the home resto, I'm with everyone else, primer and a pencil eraser... works great...
Restoration, Sales and Canadian Distributor For: AMD Sheetmetal Wizzard Direct Fit, Bolt In Aluminum Radiators Legendary Interiors SSBC & Wilwood Brakes Control Freak Suspensions Fine lines Tubing and many more... www.macleanclassics.com
