Buy one out of a junk yard.
I would make sure you don't go to low with your gear selection,
Are 3.91 the factory option on the EcoDiesel? Is the transmission gearing identical between the factory rear gear options.
I recall Bosch engineers mentioning keeping rpm below 3k to insure fuel pump longevity.
Red
