Ok,I'll try a different route,what are the correct finishes for these items Rearend housing-gloss black? Third member-natural finish(cast iron)? K frame-gloss black? Leaf springs-natural finish or flat black? Backing plates-flat black? Upper & lower control arm's-cast iron or flat black or gloss? Sway bar- Cast iron? Tierod ends-natural? Brake hub's-natural with red painted on top? Pitman arm -natural?
Trans crossmember-gloss or flat black? Thanks
Pure Stock Rules
