Originally Posted By WO23Coronet
Same thing happened to my 05 Magnum RT, replaced the crank sensor and all fixed. Believe it's on the rear passenger side of block, you have to take the starter off to get to it
Correct- I had an 05 neon with the same symptoms, crank sensor resolved the issue.
