Thanks for the nice comment on my Coronet. It took a long time to get it to where it is.
The rim's up front are the newer style (68 and up 15x7's). I welded 1/2" short bolts, with the hex heads cut off, (3) spaced evenly around the part of the rim where the hubcap snaps on. The older style hubcaps are 1 inch wider than the newer caps so adding a 1/2" does the job.
The rear are the old style 15's that I had widened. You can find them on half ton Dodge pick ups from 1960 to 66 all Studebaker's in the early mid 60s and some c bodies from 66 or 67.
I have a pair of old style 15's that l didn't use for the front because they are too narrow.
